4 members (Donf, FAST55, Shaffer's1950, greenie-reddy), 34 guests, and 3 robots.
Topics128,154
Posts1,056,838
Members48,456
Should be receiving a Mar-K bed next week for a '53 3100 and have heard two options on the assembly. My question for the experts: Is it better to assemble the bed on the truck to assure correct fit/dimensions or to assemble the bed "on the floor" then mount the assembled bed on the frame? I had thought assembling the bed on the frame would be best, but since this is my first experience with bed construction, your recommendations would be appreciated.
'53 3100 Short Bed
Texas Peace Officer - supporter of the Badge and the Blue Line
Pain is part of life, Misery is an option.
I put mine together on some large sawhorses.
I did as Ssrjim did, but I last did this almost 18 years ago.
I think I laid a couple of long 2x6" boards lengthwise (front to back) under the bed assembly. I forget how we moved the bed assembly onto the frame - probably me and three friends?
I assembled mine on jackstands then set it as a unit on the frame. Some of the bolts may be hard to reach if you assemble on the frame. Mistake I made was tightening everything before checking if the bed-to-frame holes in the wood were lined up perfectly with the holes in the cross sills. A couple were slightly mis-aligned. I could have shifted the boards or cross sills slightly for better line-up if I caught it before tightening the bedstrip bolts. Just make sure the bed assembly is square as you tighten the bolts. Your assembly instructions should guide you through the process.
Mar-Ktech
Thanks everyone for the info and I'll go the "floor" route. By the way, the folks at Mar-K have been amazing with their information, assistance and interest. Special thanks to Vickie for all her help! Thanks to the Stovebolt forum for recommending Mar-K.
'53 3100 Short Bed
It was not too hard to move. I did it with a buddy.
Fox Offline
I assembled on a small flat deck trailer. 8x6. Squared it up and installed it by myself on my 1 ton. I used 4 adjustable ratchet straps in each corner and ran them to my chain hoist and overhead crane frame and viola! 5 minute job and was able to very slowly bring it down onto the frame.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
5ptstar,
If you assemble the bed (including bed-boards) on the floor, how will you get to the nuts/bolts under the bed? Will you have the bed raised-up on wood blocks?
A bed with out boards is not hard to lift and move while on the truck. I propped mine up with some 2x4 bits. Gave me enough room to reach the bolts that are hard to get to. I put the boards in from the left and the right working towards the center. When it was assembled and just needed to be set back down a floor jack gave me the control I needed. Only 4 long bolts to the frame through the wood blocks and rubber/fiber pads. Was not too hard. It did take some time, but , was not too bad. With the bed down on the frame some bolts are hard to get to and work tight. Lifed it was not bad. The only other bed I have done was on saw horses. Still had to work from under so not a big advantage IMHO.
Steve H
