1 members (walterhvogel),
87
Mod | | | Forums66 Topics128,035 Posts1,055,559 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | I'm putting an HEI distributor in my 54 235. It has plug in wiring that I'll need to wire directly but I'm not sure which wire goes where. | | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | Thanks but that is much more information than I need. The Dizzy has 2 wires, red and brown with a connector on the end which I need to remove and I don't know where the wires go. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | One is for a tachometer and the other is for the wire coming from the ignition switch. Most GM HEI caps are embossed with "IGN" and "TACH".
| | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | OK, so I now know the wires go on the coil terminals. One wire is orange and the other is brown but nothing iin the instructions or any diagram I can find indicates which goes to + and which goes to -. Got everything else hooked up but don't want to start it till I'm sure. It's a rebuilt GM distributor designed for the 54 chevy truck and came from NAPA (48-1692) | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There was no HEI designed for a 1954 235. I looked up NAPA 481692 and saw a pic of an HEI designed for '70s GM vehicles. It can be modified to fit a 235 but is not going to fit right out of the box. | | | | | Joined: Dec 2015 Posts: 491 Unconventional Thinker | | Unconventional Thinker Joined: Dec 2015 Posts: 491 | I'm swapping in an HEI on my '65 really soon. I assume your truck has a 12v system but the points distributor gets reduced to 6v. If that's the case, run a 10 or 12 gauge wire from a keyed source such as the ignition switch or fuse panel, etc. and that's it. If you're wanting to run a tach, run a wire to the "Tach" terminal on the coil. Of course you'll need to wire the rest of the tach, but that I'm sure you already knew  If you already have a tach installed, just run the existing tach wire to the "Tach" terminal on the coil. Don't forget to re-gap your plugs to 0.045.
Shane
Shane's Toys... 2007 Forester XT Limited (2nd Owner) 1991 Cherokee Laredo (2nd Owner) 1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner) 1965 Chevy 3/4 Ton Fleetside (3rd Owner)
| | | | | Joined: Dec 2015 Posts: 491 Unconventional Thinker | | Unconventional Thinker Joined: Dec 2015 Posts: 491 | Since I am not familiar with anything older than '56, I assumed the '54 was 12 volt. Being the curious person that I am I had to research it and found out there are 12 volt conversions for them. When did vehicles switch from 6 volt to 12 volt? The '56 Chevy I had in high school was 12 volt and I am not aware if it had been converted from 6 volt, since I got the car from my mom.
Shane
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Chevrolet trucks changed to 12v at the model change in 1955 second series (Task Force trucks). 1955 first series Advance-Design trucks were 6v. | | |
