9 members (John Dlugos, Buckeye998, Gray_Ghost, Gdads51, dt235sd, rfs56trk, BCBill, Otto Skorzeny, Dusty53), 236 guests, and 0 robots.
Topics128,101
Posts1,056,172
Members48,436
Does anyone make them? Coverted from vac. to electric and mine are "crusty". Were the links different from vac. to elect. in 55 or since I had vac.,could mine be leftover 55 1st. parts ?
1955 2nd Series GMC
More pix in Photobucket
Drive 'em and enjoy 'em.... don't haul 'em....
Just more info for link issue....I only get @90deg. of sweep with this electric motor and vac. link. I may be able to fix squeaks and wabbles with work ,would like new link set...
1955 2nd Series GMC
Ken I converted my 58 GMC to electric and the wiper motor from Jim Carter used the original links from the vacuum motor. Larry
58 gmc 100 with 350 sbc
I know if you convert vac to original elec motor on a Chevy, the transmissions (links) are different. Did you use an aftermarket motor or an original one? I think I have an extra set I took off a 59 chevy.
1959 3100 Apache Fleetside
