11 members (sron48, Donf, Hanks custodian, rfs56trk, Wally / Montana, ranchojuan, jkreiner, fonz8261, TexasJim50, Forty9, Bill Hanlon),
47
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 18 'Bolter | | 'Bolter Joined: Feb 2015 Posts: 18 | I recently acquired a car with some nice wide whitewalls. I'm trying to figure out how old they are but the DOT code has me stymied because it doesn't follow the convention that I'm used to seeing. Here it is in its entirety:
DOT UPVV CA7054 A6L
The tire is The Untouchable by Cooper Size G78-15
Thanks!
1946 Chevy 3600 Pickup 1948 Chevy Sport Coupe Country Club 1963 Corvair Monza Spyder Convertible
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That code does not match up to the current style code, which was adopted in the '90s. Those tires would be at minimum 25 years old, and being an Alpha-Numeric size, most likely over 30 years old.
Bill Burmeister | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The Cooper untouchables were built in the 50's. The wide white walls went away in the early 60's. I would guess the tire to be 50 years old. If the old nylons were kept inflated, they lasted forever. | | |
