1 members (Bill Hanlon), 111 guests, and 2 robots.
Topics128,162
Posts1,056,924
Members48,458
I have swapped out a 261 to a 350 small block motor and trans truck is still on original frame but in order to do the swap had to unbolt the steering box from frame. The box will not fit back due to the 350 motor I need help on what I can do to try to use original steering or what I need to do Thanks in advance.
Find a left exhaust manifold from a 55-57 passenger car 265. It's about the narrowest manifold out there, and I believe it will give you just enough room for the steering column. Another option is offsetting the engine/trans assembly a couple of inches toward the passenger side, but that's sort of a Mickey Mouse method of dealing with the problem.
Edit: what happened to the 261 you took out? PM me if it's available.
You can also move the steering box @ 1.5 inches further out towards the wheel. Weld a piece steel level with the top of the frame to accomplish this. I used a piece of angle iron and trimmed one leg to get my 1.5 inches out and used the other leg to bolt the lower outside box mounts to.
There are a couple of pictures in the 3600 link in my sig.
Tim
Tim
1950 3600 Some Pictures
1951 3100
1952 3100 Some Pictures
