0 members (),
134
Mod | | | Forums66 Topics128,193 Posts1,057,258 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 10 New Guy | | New Guy Joined: Aug 2011 Posts: 10 | I was able to buy a new old stock 3 speed heater switch for my truck but I can't find any information about a nut or threaded polished stainless beauty ring to mount the switch to the factory dash location. Anybody have any information on this topic? Any advice would be helpful and greatly appreciated. Thanks. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Is this for your GMC? Do you have the recirulating heater or the deluxe fresh air heater? Can you post a picture of what you have... Mike B  | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 3 speed or three position, 1 being OFF? Don't know of a three speed switch on 57. Must NOT be deluxe because mounting of that needs no nut. Is it like this? http://www.classicparts.com/1955-59-Heater-Switch-Original-Standard/productinfo/68-321/#.Vl1O0-mFM5sThe GMC 2 speed switch is very similar. The standard fan switch was mounted on a heater delete plate. I think GMC had stenciling on the plate and on Chevy the knob was marked? BTW: welcome back after 4 years?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 |
1959 3100 Apache Fleetside
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Kenneth, I picked up a retaining nut that holds the switch on the panel today. If you need it, PM me your mailing address and I'll send it to you...free.
The retainer is circular, measuring 5/8 in diameter and 1/4 tall. It has 4 slots in the side (to use for tightening). The threads are inside. It sits under the knob and would be polished or chrome plated.
