4 members (Ol'55, Gdads51, Shade Baby, Bill Hanlon), 120 guests, and 1 robot.
Topics128,035
Posts1,055,570
#1136692 11/28/2015 7:34 AM
I need a new hood for my 54 3100 5 window build. went to the truck shop in Anaheim, ca and they only have 47- 53 hoods they don't list 54 and 55,hood springs are listed 47-55. so what is the difference or are 47-55 hoods the same? thanks in advance
rude1 #1136715 11/28/2015 3:34 PM
Neverdone
Unregistered
Neverdone
Unregistered
Rude,
Others may disagree but I had friend with a 54 with an earlier hood and it fit like crap . He put an original 54 hood on and it ended the problem .
Dan
#1136724 11/28/2015 4:47 PM
Originally Posted by Neverdone
Rude,
Dan
thanks for the reply, I was told that other than the hood emblem/badge it mounts different on the hood springs. what I find strange is that all AD hood springs are the same.
thanks again Neverdone, I appreciate the input.
rude1 #1136737 11/28/2015 5:22 PM
Don't know cuz I haven't swapped them but the original one on
my
'50 and the original one on my '54 both measure the same. 30"
across the front and flat on the bottom, about 48" in a
straight line from the front to the back and both about 55"
across from a common point under the back across the firewall.
Sure looks to me like they would swap even up.
Like to hear from someone that's actually tried it, even
thought the parts book puts a break in at '53/'54.
I'll bet Tim L. or Brad A. have tried it.
Denny G
Denny G
Sandwich, IL
Denny Graham #1136747 11/28/2015 5:52 PM
my
Denny G
thumbs up Denny, great input. do they mount the same to the hood springs?
rude1 #1136786 11/28/2015 10:10 PM
I have installed a 54 hood on a 49 cab. It fit perfectly.
The only difference between the 54 and the 47-53 hoods is the lack of recesses for the front emblem holes. The earlier hoods have the recesses. The holes are in the same locations on both hoods, however.
Hoods are not the easiest item to install, especially if they have been damaged. I suspect that may have been the issue with Neverdone's friend.
Carl
52Carl #1136791 11/28/2015 11:19 PM
Carl
thanks 52Carl, I want the hood to be perfect mostly because of the heat, don't want it all bondo'd up. thanks again
rude1 #1136825 11/29/2015 2:56 AM
Another difference (in addition to the difference described by Carl) might be that some A-D years' hoods had side emblem holes for two plates on each side (late 1949 through 1952). I assume there would be extra holes when using single side-emblems?
rude1 #1136847 11/29/2015 4:49 AM
rude1
According to the 1929-55, Parts and Accesories Catalog, the hood is listed as:Panel,Hood Top
Year Model Part Name Part No.
47-55 COMM.(1st Ser.)........left..........3701465
47-55 COMM.(1st Ser.)........right.........3701466
It sure seems to imply that the 47-53 should fit your 54. Of course, as the other guys have mentioned, there are different holes for emblems. I do know that the side 3100 call out is the same on a 54 as a 53. I do know from experience that hoods are tricky. They can bend a tweek if not handled correctly when they are off. Hope this helps.
Rugo
Steve Rugg
53 3100
tclederman #1136897 11/29/2015 5:18 PM
thanks tclederman, I don't think the holes will be a problem. it's the fit that concerns me. thanks for the input.
Rugo #1136904 11/29/2015 5:30 PM
Originally Posted by Rugo
rude1
Rugo
great info Rugo, that's what I needed. I bought a used hood which looked good until it was mounted. one side was perfect while the other side was about 1 1/2" off. turns out it had some damage on the top of the hood that wasn't very noticeable. since I don't want a bondo queen, i'm opting for a new hood. thanks
rude1 #1136905 11/29/2015 5:33 PM
just want to say thanks for all the help. you guys are awesome.
rude1 #1137047 11/30/2015 2:07 PM
When we put hoods on the first try is with no latch, hinges, NOTHING, just the bare hood. If it fits the hole then any misalignment from that point on is caused by hinges, latches, etc. If it doesn't fit the hole then the brace rods to the firewall, the shims at the core support, the shims under the core support, the rear often needs to be drawn together or stretched apart, and whatever else is needed for a proper fit. Once the bare hood fits right then add everything else ONE AT A TIME. It saves much time not jumping from one item to another since you will know exactly what causes the misalignment.
Evan
coilover #1137073 11/30/2015 5:16 PM
thanks coilover, you just dotted the i's and crossed the t's. much appreciated, thanks.
