0 members (), 72 guests, and 3 robots.
Topics128,194
Posts1,057,263
Members48,466
Page 1 of 2 1 2
Well I found a part in my steering wheel parts box and not sure what is was. I was told by a couple of folks it was a oil slinger that had two functions. First one was to keep the seal on the timing gear cover from being directly hit by oil and damaging it. The second function to sling oil on the gears. I was somewhat confused because on how it was mounted because I was told it went on after the crank gear and the harmonic balancer kept to from touching the toming gear cover. Now I do not remember installing it. Any advise should I wait till the seal leaks and when I replace the seal install it? Can someone verify this info is true?
thing 1
thing 2
Can someone name this part?
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
The GM parts book only shows the slinger/thrower used up to 1938.
Group 0.647
My Blog
Riding in the Passing Lane
Oil slinger is the correct name for it. It is there to keep excess oil away from the seal. I think I would run it awhile & see what happens. Unless you need something to do & pull the seal back out.
1972 Chevy c10 Cheyenne Super
I had 3 motors a 1955 and a 1958 to 1960 can not remember the correct date i used for parts and my 1956. So i do not remember where it came from. At least i know what it is thank you.
56 Chevy 3100
Lol i gots plenty to do besides if i do pull it i will this time fix those 2 little bolts in the oil pan that hokds the timing gear cover and that cool contraption to drill out the snout on the crank gear. I was rushing and it was my first build i guess i should have slowed down and took more pics rookie mistake. If it was going to harm something i guess i would break out the wrenches
56 Chevy 3100
D Online: Content
Withdrawn from thread to minimize confusion.
Denny G
Sandwich, IL
"Way back when" would have to be before the 216 was introduced. All the 216/235 crankshafts I've seen only have a smooth surface at the back of the crank for the oil seal to ride and the flywheel to mount, no slinger. I believe some of the earlier engines might have had a slinger and a reverse-helix groove to transfer oil back into the crankcase instead of a seal.
Looks like a front crankshaft oil thrower/slinger to me, they were used from 1930-38.
My parts book shown Gp. 0.758 "Crankshaft Oil Thrower",
1937/38...ALL...(1-1/4 ID x 3-1/4 OD x 7/16 width)...p/n 838265.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
D Online: Content
Denny G
Sandwich, IL
My 1951 book has it...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
1954 parts book is the last year I see them listed for a 6 cyl. Bottom of page.
1940 was the first year for a rear seal, before that the crank had a oil slinger as part of the crank at the rear.
My Blog
D Online: Content
Denny G
Sandwich, IL
Took apart my 56 261 a few months ago and it had one. My 55 235 in my truck now does not have one. The first time i saw one was from the 261. See Picture Below.
Oil Slinger
OIl Slinger 2
Denny,
I'm not sure I understand your question...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I think Denny is asking why Chev changed the group number 0.758 to 0.648.
My Blog
I have not looked in all of my parts books, but it looks like Chev changed the group number at least three times.
1950, 0.758 Part #838265, called "Thrower".
1954, 0.647 same part number and name.
1961, 0.648 but this only lists a V8 and called "Slinger".
My Blog
From what I can tell those two groups never overlapped in any parts books.
Maybe once Chevrolet retires a group number it's gone and they don't waste time researching to see if a new part might fit in an abandoned group...just take the next number and run with it.
Also, they changed the wording from "Thrower" to "Slinger", so that might be another reason to give it a new group.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
On another note, Chevrolet sold a spacer ("Ring" on package) for 1955 all (second design)Group 0.622, that appears to take the place of the slinger.
I have a bag of these, NOS GM 3723794 and can not figure out what Chev was thinking.
My Blog
Dave,
0.647 isn't in my 1951 book or in anything newer than 1956 (I have a gap from 51-55). Seems all of the slingers shown in 0.648 are for V8's as mentioned above.
Maybe someone deleted 0.758 and got there wrist slapped because Chevrolet still had inventory and they reinstalled it as a new group (grabbing at straws here...lol).
So, is there another group that we haven't discovered...why do these 6-cylinder engines have slingers but they don't show up in the parts books???
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Dave,
No 0.622 in any of my books, what year book did you find that group?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
post deleted...duplicate
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Sorry, it is Group 0.662, in my 1961 book.
My Blog
One more thing. I have worked on a lot of 235s and have seldom seen a slinger on them.
My Blog
D Online: Content
My point!!!!
I don't see where you're finding a 0.622 group in any of these
three parts books, which are the only ones I have access to:
http://chevy.oldcarmanualproject.com/parts/1929_41/index.html
http://chevy.oldcarmanualproject.com/parts/1929_54/index.htm
http://chevy.oldcarmanualproject.com/1929_57chevyparts/index.htm
None of which makes any difference to me since my 1959, 261
didn't have a slinger/thrower/ring behind the balancer and I
don't see any reference to one for that engine in any parts
books or service manuals.
dg
Denny G
Sandwich, IL
0.662, Denny
1/2 of one year (1955 2nd series)?
Here is a picture of the spacers.
I assume these were used to get the belt in alignment, but I have never seen this in print.
My Blog
D Online: Content
And what were those for Dave?? Why would the balancer need to be spaced out??
dg
Denny G
Sandwich, IL
Read the second foot note down from the top of this page (it's the the foot notes for Group 0.659 Balancers).
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0147.htm
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Good eye Mike, but I still don't get it's purpose.
My Blog
I'm thinking there was an engineering change, they planned on using a Slinger and then changed their minds and needed a spacer until they corrected the issue in '56...just a guess.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
D Online: Content
Ah ha! When in doubt, read 'all' the instructions!
I sure didn't catch that. It's clear that if you didn't use the
slinger that you would need to space the damper out to maintain the
pulley alignment.
But, it's still very sketchy as to what engines the slinger was
used on. Seems to be all over the place depending on which
parts book you're using.
Why didn't you just throw that darn thing out in the ditch
Jamie and we could have avoided all this confusion.
dg
Denny G
Sandwich, IL
Even after all of this research I'm still confused as to wy only 55-2 6-cylinders need this spacer. What's different between 55 and 56 6-cylinders???
If it is to replace the space left by not having a Slinger, why aren't there 6-cylinder Slingers in the book?
If Spacer is to take the place of the Slingers and they made corrections in '56 (no spacer needed), why isn't there a different balancer (cast the Balancer longer to eliminate the Spacer)? Or, if they made the changes to the Crankshaft (machined the shoulder longer to put the Balancer in the correct place), why aren't there different Cranks between 55-56?
This may be a mystery we can't solve...
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike, I have had these shims for years and have not come up with a good explanation. I also have never seen one on an engine.
My Blog
Remember, you will only find them in 1955 second engines...
Something has to be different...generator belt allignment, timing cover interference...something???
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
How about the thickness of the crankshaft timing gear? Any difference in part numbers?
D Online: Content
No help here:
Parts and Accessories Catalog P&A 30 March 1957
gp. 0.728 GEAR---SPROCKET, Crankshaft Timing (Steel)
40-57 ALL 6 cyl (27 teeth----3 1/8 OD) pn. 3835371
53-55 CORV. 6 cyl. (stamped 73) 3836073.
Parts Catalogue No. 651 December 1964
1958-65 / ALL WITH 230 and 235 ENGINE
Parts History Catalog P&A 30H January 1973
USE 03846967 07-65
Parts and Accessories Catalog P&A 31 May 1966
55-66 ALL (6 cyl.) (exc. 292) GEAR, (27 teeth–3 1/8 O.D.–stamped “71”) 3836605
63-65 ALL (292) GEAR, crankshaft (stamped “71”) 3835371
66 ALL (292) GEAR, 37 teeth 3882892
Parts Catalogue No. 691A November 1968
3835371 1967–69/6 CYL
Parts and Accessories Catalog 31 January 1964
63-64 ALL (292) GEAR, crankshaft (stamped “71”) 3835371
Parts and Illustration Catalog 30 March 1958
3835371 Mix w 3836605 3-1-58
Master Parts Catalog April 1950
839259 Use 3835371 4-1-49
Truck Parts Catalog 31S June 1971
40-66 All (6cyl.) (exc. 292) 3836605
Part Number Replacements and Supersessions 80TS-RP September 1979
3835371 replaced w 3836605
Denny G
Sandwich, IL
Ah, a new stove bolt 6 mystery.
An enigma that has/will engender interesting speculation.
There is no mention (that I can find) of that slinger/shim in the 1955-2nd Series Truck Shop Manual.
dg
Well at least you all did not say its apart of the steering column. Since i do have it out i could accidently drop under the work bench. Really guys i am reading this and just amazed of your knowledge plus i am also being amused too. You learn something new everyday especially on a 5o year old motor.
56 Chevy 3100
D Online: Content
That's what keeps one interested in these old heaps of iron Jaime.
It is amazing how one little coaster size tin washer can
generate four pages of dialog. Just goes to show you how
starved for attention some of us are.
dg
Denny G
Sandwich, IL
Is a whole 1/16" of fore/aft position of the damper really worth all the effort of installing a spacer? A good dose of castor oil will cure the problem that causes that obsession.
Page 1 of 2 1 2
