| | | Forums66 Topics128,155 Posts1,056,868 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 54 | Does anyone know of a good place (forum) to get info on my 74 C65 flatbed dump truck? I need kingpins.
Sorry for posting here but just looking for help. Thanks
..."some gave all, KIA"...
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 57NAPCO, there are three different axle possibilities listed for that truck, an FO70 (7000lbs.), an FO90 (9000lbs.) and an F120 (12,000lbs., if you can identify the axle we can supply kingpin kit part numbers | | | | | Joined: Sep 2007 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 54 | Thanks 3b, Looking at the spid, F94402- front springs -9000#
Also saw, ZZ4401 FRT AXEL-F070
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 57NAPCO, the kingpin set for the FO70 axle is Moog p/n 8491B $35.79 at RockAuto, hope that helps. | | | | | Joined: Sep 2007 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 54 |
