Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (Mr Bailey, baldeagle, frogfarmer, cmayna, JW51, Peggy M, 216wny, tclederman, 1 invisible), 35 guests, and 1 robot.
Topics128,005
Posts1,055,261
Members48,418
#1136749 11/28/2015 6:01 PM
We just got finished redoing the doors and rebuilding the hinges. When hanging the drivers door, had a problem with alignment on the lower hinge. Had to loosen the cowling bolts to get the holes to line up. Once mounted the door won't line up and little adjustment. Bottom won't seal. See pictures.
https://www.dropbox.com/s/6vc971nqah8t3r5/20151128_110248.jpg?dl=0
https://www.dropbox.com/s/wagapeeddg0drmr/20151128_110303.jpg?dl=0
https://www.dropbox.com/s/w5nqshrktkzw834/20151128_110311.jpg?dl=0
https://www.dropbox.com/s/ti1cjij7mfko6xo/20151128_110326.jpg?dl=0
Is the hinge sprung? If so, how do you fix it? All suggestions welcome.
Deron
God made man to go by motives, and he will not go without them, any more than a boat without steam or a balloon without gas.
FLSTOVER #1136770 11/28/2015 7:55 PM
Did you use the thinner rubber? That is what I had to do.
FLSTOVER #1136778 11/28/2015 8:43 PM
I can't even force the bottom in. That's why I think the hinge is the problem.
Deron
FLSTOVER #1136783 11/28/2015 9:16 PM
You need to bend the hinge inward at the first bend at the door
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
FLSTOVER #1136826 11/29/2015 3:03 AM
something to consider, a long shot here. On my '50 passenger side lower hinge, the factory welded "nuts", where the hinge bolt goes thru, was completely rusted out. Hard to see with the inner to outer cowl piece in the way. Had to reweld a new set of nut plates to the backside, will find out how accurate it is, when I rehang the doors this winter, about 5 yrs later. Try grabbing the lower hinge, and see if there's any movement in it, while it is bolted down. By looking at the pictures, I would suspect rust out, in the lower cowl area, Lotsa moisture down in FLA.
