1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 16 New Guy | | New Guy Joined: Jun 2013 Posts: 16 | Good morning,
Just curious if I can use a thrift air heater core in my deluxe heater box.? If not, can some one please explain why? Thank you!
Kaycee | | | | | Joined: Jan 2007 Posts: 220 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 220 | From what I recall they are different sizes. Assuming you got it to stay in place, if it does not fit right you will have air passing through and around the heater core so you won't get the hot air you want in the cab. | | | | | Joined: Apr 2014 Posts: 62 'Bolter | | 'Bolter Joined: Apr 2014 Posts: 62 | I tried to use a repro on my 61. It would have been way to much work to make fit. I ended up having the original core rebuilt. Works great.
1961 Long Stepside Apache 10, original 235, 4 speed and 3:90 posi totally stock (owned 12 years) 1966 Chevelle (owned 53 years) | | |
