0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2015 Posts: 28 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 28 | Have a 1937 Chev. 1 1/2 ton truck. Number on engine is the same as on the title dating back to 1974. I understand the engine # was used on title in some states. How do I find the casting #, or engine #for 1937?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Phillip, Welcome to Stovebolt.com If the 1937 216 is the same as later 216s, here are locations of various codes. Post your codes here and people will help you figure out what you have. | | | | | Joined: Nov 2015 Posts: 28 'Bolter | | 'Bolter Joined: Nov 2015 Posts: 28 | Thanks for the info. I kept searching until I found out what I needed. Found out I had a 55 235cid. | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | If you have a 1955 engine and the title matched the engine, you should confirm the title has the correct year. Also, don't get rid of that engine as that's the only link to your title. Call you local DMV to see what you need to do if you want to swap engines. Mike B  | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | If you are planning on modernizing it I would check with the DMV about using the serial number on the title instead of the motor number. | | |
