| | | Forums66 Topics128,180 Posts1,057,149 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 16 New Guy | | New Guy Joined: Aug 2015 Posts: 16 | I am on a mission to install my 8 board bed. I have prepped the pine boards and purchased the required metal strips, bolts and fasteners.
The question at hand is regarding the installation of the outer boards. These are the two narrower units with 2 predrilled holes. I got the passenger side board in and loosely attached the fasteners. Moving to the drivers side I observed that the boards don't have groves on both sides like the other 6 boards. To accommodate the metal strips. In their present state the side of the outer board closest to the differential does'nt have a grove. Am I on the correct path? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Yes the outboard pieces on both sides are not grooved where they go under the welded side strip. They can sometimes be a challenge to get under existing sides. Install them first, leave the bolted connections loose, if you need to you can carefully bend them up slightly. If you notice how these beds are built it is all about movement, between the boards, the eccentric washers with oversize hole for the attachment bolt to go through the board and the strip design. They grow, shrink and constantly flex, both loaded and unloaded. I have attached a folder of pictures that may help. https://www.flickr.com/photos/advance-design_parts_co/albums/72157631884205225/with/8130479153/ | | | | | Joined: Aug 2015 Posts: 16 New Guy | | New Guy Joined: Aug 2015 Posts: 16 | Thank you so very much for the pictures and your comments. I am back on track. Feeling confident that I can bolt this beast together. | | | | | Joined: Aug 2015 Posts: 16 New Guy | | New Guy Joined: Aug 2015 Posts: 16 | Just a quick update that the bed is installed. Thanks again for the help from a fellow bolter. MERRY CHRISTMAS | | | | | Joined: Sep 2013 Posts: 2 Moderated | | Moderated Joined: Sep 2013 Posts: 2 | Thanks Brad. I'm reassembling my 51 chevy bed and your pictures help a lot.
JoeRod
| | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | Is this the same for a 46? Are the outside of the outside not groved?
Steve
'46 Chevrolet 1/2 T. Pickup, survivor - sold '31 Ford Model A pickup
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Outside boards on the 46 are not grooved. They slide under. Dan | | |
