| | | Forums66 Topics128,035 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | When i turn the steering wheel to dead center in the 4 lock-to-lock turnes, it is about 3/4 of a turn off from steering straight. Can I pull the wheel off and re-align it?
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1953 GMC 1-ton?
"Can I pull the wheel off and re-align it?"
Yes - if/when you "can" pull it off you can re-align it. Be careful - some people force/hammer off the wheel and damage it. | | | | | Joined: Aug 2011 Posts: 226 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 226 | Is there a special tool that is required to pull the steering wheel or just a standard steering wheel puller? | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Standard one works. Did you check for the slightly tight spot as you turn the steering wheel through the midway point with the drag link disconnected? This will help verify if the steering box is adjusted properly and that you are indeed at the midpoint to put the steering wheel on in the correct position. Carl
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Advance Auto Parts and others loan steering wheel pullers for free.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The "standard" old school puller/pusher technique was: - sit in the driver's seat - loosen the steering wheel/column nut a turn (or, maybe two) - push up on the steering wheel with you legs - cleanly strike on the top of the stereing wheel column, to see if the wheel will "pop"upwards - if that fails, use your steering wheel puller (I use a HF one like this one .) | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Thanks guys! Yes the wheel has more drag across the middle of the turning.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The best way to get it centered is to drive it down the road & put a chalk mark on the column & the hub. Line up the marks when you get it in the shop. Pull the wheel & put it back on center. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | The "standard" old school puller/pusher technique was:
- sit in the driver's seat - loosen the steering wheel/column nut a turn (or, maybe two) - push up on the steering wheel with you legs - cleanly strike on the top of the steering wheel column, to see if the wheel will "pop"upwards It would be best to let your toothless assistant do this. He has nothing to lose.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No lost teeth. The nut is still in place.
I have never had to use the first four steps in the technique I posted.
The puller tool has always worked for me.
| | | | | Joined: Feb 2000 Posts: 5,198 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,198 | If you can, pull the dragline loose before centering the wheel, so you know for sure you are centering the gear box and not the wheel stops on the axle. Over time someone may have adjusted the wheel stops incorrectly, this will make the steering box seem out of adjustment, so the steering wheel is moved.
If the truck drives down the road with the steering wheel off center, and you are reasonably sure the tight center adjustment is right, then the wheel is just installed incorrectly. But, if the center adjustment ( tight spot ) is off to one side, the axle locator pins, steering arms, or spring hangers are most likely in the wrong spot.
I never could get mine to center while driving, I finally made a adjustable drag link to dial in the straight ahead adjustment. My truck is a mishmash of parts from different years.
| | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I looked at two different pullers but there were no extra holes drilled in my wheel to run the bolts into. I started to fabricate a strap to wrap around the back of the wheel to use with the larger puller but I gave it one last "heave-ho" using the "toothless" method and by golly it came loose using some PB Blaster.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Do you have an after market wheel Chad???? I've never seen one that didn't have the two puller holes in it. A steering wheel puller is about the simplest tool you can make for your tool box. A few bolts any chunk of steel that won't fold up under a tiny bit of pressure, a drill and a tap. http://www.pbase.com/dennygraham/image/161940335 If you can't fabricate one of these, then honest to good, you orta be leaving any mechanical work on your truck up to your mechanic. dg
Denny G Sandwich, IL
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Denny- what size is the center bolt you used for your puller?
Thanks Brad Wrench Fetcher, PhD | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | No sir, it is the old GMC wheel.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's a new one on me Chad. Have to check with my buddy on his '47 and see if he had holes in his early wheel for the puller. Didn't happen to take a picture I could add to my reference file, did you??? The later ones had the holes, and all of the original steering wheels I've seen have had them. http://www.oldcarmanualproject.com/manuals/GMC/1966/Series%204000-6500/image443.html dg
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | On my 38 Master, there are no holes in the steering wheel, not like my truck. So the solution was to use home made J hooks on a puller. | | |
