1 members (Thomaslb),
138
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 92 | I am working on the rear brakes of my 1949 4400 single speed rear end and was wondering if there is any reason I can't pull both axles at the same time without messing up the pumpkin.
1949 Chevy 4400 216
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GIJOE298, there is no reason I can think of why both axles can not be pulled out of any given rear axle at the same time, hope that helps. | | | | | Joined: Mar 2010 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 92 | Thanks 3B. I didn't think it would cause a problem but wasn't sure so thought I would ask. thanks for the help.
1949 Chevy 4400 216
