| | | Forums66 Topics128,090 Posts1,056,381 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 22 New Guy | | New Guy Joined: Jan 2015 Posts: 22 | Does anyone know the screw size for the lock knob on the drivers side door of a '37 half ton? Standard screws don't seem to fit. Looks like a fine thread. http://www.oldchevytrucks.com/sku/images/dp/dp129.jpg | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Does the other side have one to take to hardware store? or measure Dia. and count threads. If you have a screw that almost fits but threads are too course, then you know it's the fine of that size screw. Maybe in Canada your stash is all metric?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2015 Posts: 22 New Guy | | New Guy Joined: Jan 2015 Posts: 22 | There is no interior lock on the passenger side door on these things.... From what I can tell it's probably a 5-40, 5-44, or 6-40 machine screw and 3/4" long. None of these are readily available at your local Home Depot. I did try one fastener shop yesterday and a royal A-hole that was in no mood to help find screws for an 80 year old truck was working the front desk. So, I'm hoping someone can confirm the specific screw and I'll find it somewhere. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Would be surprised if they used a 5. Could be a 6 which is only .138 Dia. Just buy one of them all and see what fits, they are pretty cheap. Small and long is also hard to find. Fine is sometimes difficult to find locally. Unless someone wants to unscrew their 80 year old screw and measure. Engineers try to use the same size for lots of things to save money. Might there be another interior part that uses that screw so you can size it? What head configuration do you think it is? Pan, Flat...82deg...100deg?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I'm pretty sure mine is 6-32. I've got a '40 but they may be the same. I think these are called fillister head machine screws, like the ones holding on the inside handles.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Jan 2015 Posts: 22 New Guy | | New Guy Joined: Jan 2015 Posts: 22 | It is a 6-32!!!! There was some crud on the first few threads and it wouldn't go in initially. | | | | | Joined: Jan 2015 Posts: 22 New Guy | | New Guy Joined: Jan 2015 Posts: 22 | The pan head I have fits, but looks stupid. I expect that Dennis is correct and the original was a fillister. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Would be slotted head or clutch head back then I suspect. You will find one on something around the house sooner or later. Or find at Hardware store. At least the knob is on now.
