1 members (Southerntruck),
73
Mod | | | Forums66 Topics128,049 Posts1,055,635 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | Hey guys,
53 3800 1 ton DRW.
The truck will end up with a 250 engine SM420 Trans 8R-19.5's 14 bolt rearend
Question:
Is 4.11 gonna be the desired ratio or will something numerically lower be better or OK. I.E 3.73 or even a 3.42 that I have already.
Probably see more back roads than highways and it will pull a trailer at some point. (3000 lb tractor on the trailer).
Larry W.
1953 3800 Dually Flatbed
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mrf1002u, with your tire choice and probable work load I would stay with the 4.11 ratio. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I wouldn't go any faster than 4.11 or you will wind up with a gutless dog. | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | I'd do 4.11s. Actually with tall tires my 5.13s did better at 50-55 mph on my truck. And in your case trailer brakes
1953 GMC 1-Ton Pickup with 350 and 700R4
