| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 17 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 17 | My turn signal mechanism had no clicking sound and I was always leaving it on for miles and miles. Someone on this forum suggested that Radio Shack had a inexpensive sound device. Well part number #273-0068 buzzer, worked, I wired it in to the flasher and extended a wire back under the dash board with the buzzer attached. This buzzer is a screaming, high pitched, loud and piercing to the ears. I took some tape and covered part of the buzzer with the tape. It now is ok. Thanks for the great idea. Richard Chevrolet 1954 3800 | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | That is a great Idea, Richard -- Thanks! Is that for 12 volt only or will that work with a 6-volt system, too?
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Jul 2014 Posts: 17 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 17 | John, I am not sure 6V or 12V , I would think it might work on 6V ??????????????? Richard | | |
