Hi DennisM,
I guess what I'm saying is that the seal
used in the original hub would not work with
roller bearings. The seal used with the ball
bearing rides on the inner race of the rear
bearing. When you replace the ball bearing
with the roller bearing the original seal
would have nothing to ride on. Chevy Duty
must sell a seal that can ride on the
spindle directly.
Anyway I think for the price I'll probably
use my ball bearing as long as they are
good. It good to know that roller bearing
can be used in place of the ball bearings
thou. If the ball bearings give me trouble
then I'll switch them to roller bearings.
Does anyone know if you can still get
short fiber wheel bearing grease? It's
what the Chevy Repair manual says to use.
