3 members (Gdads51, 2 invisible),
333
Mod | | | Forums66 Topics128,162 Posts1,057,068 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Convex? Or flat? It’s rumored that the tappets had rounded bottoms so they would rotate. But…I’ve got a box of NOS ‘54-‘55 261 tappets here in the shop and they’re as flat as flat can be. Checked the original ones that came out of my ’59 261 on the surface plate and guess what…..the faces are as flat as a Pugs puss. http://www.pbase.com/dennygraham/image/161876786 Another way that an engine designer can rotate a lifter is by offsetting the lifter bore centerline to the cam lobe. And if you look at the alignment of the lifter bores to the cam lobes in this 261, some are offset….and some are not. Tapered cam lobe is another feature used by some designers and in this engine, some of the lobes are tapered about .004”……and…..some are not. I don’t have any idea where you would find the specs on the cam and lifter design for these engines to see what method was used, but it would be interesting to know. The taper required in some cases is so slight it’s difficult to tell if it’s taper you’re measuring or just normal wear. And, Vintage engines had flat cams, flat tappets, tapered cams, convex tappets, and offset bores. Nothing cut in stone and every designer had his own idea of how to get the most life out of the cam and lifters. DG
Denny G Sandwich, IL
| | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | Denny, I have used the back side of my old 645 Sioux for resurfacing lifters. It is a 50 to 60 year old machine, but it works. I set the angle between 1° and 2°. If you figure the radius of the lifter surface, the 1° to 2° angle will give you a crown, but I don't think it will be enough to measure the way you are trying to measure but it will cause the lifter to spin. If you Google something like "solid lifter resurfacing", you will find quite a few people companies that resurface them. Why not call them and discuss it with them.
I mess with Y-Blocks and GMC. They both require a crown on the lifter. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | When I get time, I'm Probably gonna stop by the local engine rebuilder and see if he's equipped to reface them. Haven't had a chance to do any surfing for "solid lifter resurfacing", but since things have been so slow around the bolt lately and I'm waiting on parts so I'll take a look. Good idea, i.e. calling around also thanks for the suggestion Ken. Been on the lookout for some NOS "exact" replacements but that seems to be a bust. Had the alarm set to bid on some NOS GM rocker shafts in the box yesterday but I was in the barn when the alarm went off and my "big old wife" just shut it off, went back to her cooking show and told me an hour later when I came in, "Oh, I shut your alarm off, what was that for?" That pair of shafts had one bid and went for $9.99. Needless to say I was not a very happy camper to be around the rest of the evening. Another wild idea on the lifters is to set up my high speed die grinder in the lathe. Biggest obstacle there is the lack of coolant and surface finish. http://www.pbase.com/dennygraham/image/161885728/largeThese lifters are definitely not crowned. When you can check new ones on a granite surface plate with no rocking there is no doubt they are "flat". The odd taper I'm finding on the lobes may account for the fact that a few of the lifters still look very good and others are dished, the worst one .010". I need to match the lobe taper I see on some of the lobes to the lifter face to see if they are connected. Still haven't found any info on the cam lobe design for the Stovebolt other than some lift and timing data. http://www.pbase.com/dennygraham/image/161885727/large DG
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Denny, use a die grinder on the compound rest, and set it for a 1 Degree angle. Center the lifter up in a 4-jaw chuck and use a fine-grit Cratex rubberized wheel in the grinder. You'll get a mirror finish without needing any coolant. That's how I finish gun parts that need a super-fine polish. I use a 22K RPM electric die grinder for that type of work. Be sure to cover the lathe ways with a tarp or some other way of keeping the grit off the ways, and clean up thoroughly afterwards. Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's the plan Jerry, did ya take a look at the picture of the temp setup I dug up? Still unpacking stuff from those boxes that made the BIG move in 2012. 24,000 rpm on that Craftsman Industrial die grinder. That one is from back in the day when Craftsman made some halfway decent tools. It's been in the family for better than half a century, pop used it on his South Bend bench lathe when he was alive. Now, that's an idea, I mean the rubberized abrasive. I've got/had a couple of the 1"x 6" 3m wheels on pedestal grinders in my shop for many years. I use them for deburring and blending edges on parts I've machined. http://www.pbase.com/dennygraham/image/161889589/large I think I might have a hard time taking .010" off the worst ones though with a 1" diameter wheel. And I would have some doubts about how flat it would make them. But, your right, I think they would be good for finishing. dg
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Cratex comes in about 3 different grits- - - -I believe the brown ones are coarse, gray is medium, and white ones do the mirror polish I like on trigger sears with the letoff weight measured in ounces on target rifle triggers. For a little more aggressive rough-out try the Roloc abrasive discs in 1 1/2" diameter that twist onto the flat rubber backing discs. They're available in the 1/4" shank diameter that fits the die grinder collet. Jerry
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | When I took my 53 235 engine to the machine shop to be bored, etc, I brought along the cam to get his opinion on it. He pointed at the points of the lobes. There was heavier wear (looked minor to me) on one side of each lobe. He said that this area was originally ground higher than the other side to cause the lifters to spin. Made me scratch my head. What say you?
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Next time bring along a wheelbarrow- - - -what he's spreading around will make your garden grow nicely next spring! Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Here is Greg's diagram. I deleted my foolishness.
| | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | I e-mailed Denny a page from a 79 Iskenderian Cam catalog and it has a page showing both the convex lifter face and the 1 degree taper on the lobes to make the lifters spin. They exaggerate it in the drawings but actually give the 1 degree offset/convex, | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | Denny, I am assuming you are talking about losing a bid on eBay. I have been using this site for bidding for over 10 years. http://www.esnipe.com/It keeps me out of bidding wars and then places a bid 6 seconds before the end of the bidding which doesn't give other bidders time to bid against me. If it is an item that I really want, I usually bid the opening bid to keep the seller from removing the item. My esnipe bid then bids the maximum I am willing to pay 6 seconds before the end. | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Denny, Go to the GM Heritage Center and look at 1935 Master Cars...I know it's a 206, but they do show the convexed lifter with dimensions, I bet the convex it the same for the later engines (why re-invent the wheel). It's way down on web page 86 I think... Mike B  | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | If they're only supposed to make local contact: 1. why are the tappets so strongly offset from the lobe center? 2. why are the tappets so big? | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Panic,
Tappet diameter is determined by the maximum valve lift velocity, if the velocity is too high, the cam will overrun the tappet face. The illustrations posted by Tim and Greg show the lobe "elevation view" of the situation, but the velocity portion is best considered as the lobe reaching in and out of the page. Think of what the cam and tappet look like if you could view them along the camshaft instead of beside it. Most automotive applications have settled on a few 'standard' diameters since most engines performed well with the velocities those allowed.
The best reference for this is a book by an oldtimer named Mike Turkish. He worked for Eaton Corporation's Valve and Lifter division back in the 1940's 1950's. I have a copy of his book somewhere deep in my files. If I can lay hands on it, I'll post some background.
Interesting topic.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Tappet diameter is determined by the maximum valve lift velocity
and the lift velocity of those engines is very, very low. This leaves us without a reason... | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Nope Ken, didn't lose the bid, fact is, I missed it completely. I was working in the barn when the alarm in the house went off. I’ve heard of esnipe but never used it. I usually snipe it myself in the last 10 seconds. I'll have to keep that in mind. Ok. I've already talked to George and Dave about this but for the record, 1) Isky’s catalog is addressing their cams and cams that are similar to their cams, not all cams and lifters. 2) The 261 lifters, which are in the '59 engine I have here are flat. If you know anything at all about inspection you can see in the pictures of them being checked on a black granite inspection plate, that their faces check out perfectly flat and perpendicular to the sides on the NOS GM early lifters and on the later stock two piece lifters. A 60 inch radius on a 2.315” by .989” lifter would give you a .002 crown, which would rock like your grannie’s bent wood rocker. I haven’t been able to find a NOS GM cam but I’ve got a reground 3836484 cam coming. If it’s been ground to the original specs then I should be able to see the taper. Thanks to George, I've got some NOS 5231880 lifters coming which are the factory replacement for the discontinued two piece 5231445 lifter. I'll add the pictures of those flat faces to my album if any one cares to see it. More documentation. http://www.pbase.com/dennygraham/261_solid_lifter Like to see that data if you find that book BD. And Mime, that is obviously true and documented for 1935 but not true for 20 years later.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | This simple thread is starting to look like the "Never ending story." One of our longtime 'bolters turned me on to an interesting site. I'm new to it so I don't know much about it, other than It's loaded with info about the application and cross reference to aftermarket replacements, in this case, it's the GM 5231880 lifter. The thing that set me back on my heels was their application listing for this tappet. According to the list it was used all the way up to 1974 in many Chevrolet and GMC engines. Which to me means they should be quite plentiful. At fairly great expense, I'm managed to scarf up a set of GM NOS 880 lifters. What this also tells me, is that GM used a flat face tappet in a whole bunch of their engines, way to many to list here. I'm definitely going to book mark this site. So I'll pass the link on to anyone who might be interested in fact finding and tying up loose ends as I am. http://www.yoyopart.com/oem/12510095/gm-5231880.html#interchange Thanks George. Denny Graham Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sometimes, something just has to be said: NOS 5231880 paper weights I'd be ashamed to put these up for sale for anything other than the cost of shipping, which even then, they'd be over priced. Denny Graham Sandwich, IL
| | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | According to the list it was used all the way up to 1974 in many Chevrolet and GMC engines Stovebolt inlines and GMC V6's- - - - -they're still 40-something years obsolete. Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | So are model-T's, A's, Packards, but they're still collectible and hold some people's interest.
dg
