2 members (cmayna, IHPWR),
142
Mod | | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | It's been a really long time since I've been on here mainly because my truck has been together and running for the past few years. Well, this summer my original radiator gave up the good fight. So I had to replace it and decided to go with a less expensive KKS aluminum radiator from ebay. It arrived yesterday and I decided to toss it in this morning. Turns out it doesn't fit and I'm slightly frustrated. The way the mounting bracket is welded onto the radiator, it sits back towards the engine by at least and inch or two so I'm running into the fan.
Does anyone have experience with KKS radiators or any other additional information that I'm missing here? Is this the correct radiator? Would a later model radiator sit further back than the 1950?
Thanks for any help. I'd post pictures but can't figure out webshots after taking several years off. | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | RedGreen,
I purchased my aluminum radiator from Auto City Classics in Minnesota. After I received it I found out it came from KKS. Haven't tried to install it yet. Took the measurements from my old original radiator and everything seemed to line up. Hoping I don't run into the same problem. Where is the fitment issue? I'm installing the radiator I got through ACC from KKS in a 1949 Chevrolet 3100 1/2 ton. Have you checked your motor mounts? Maybe the engine has moved forward if the motor mounts are breaking down? Just a thought.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Chevy radiators mount on the rear of the frame, GMC mount in the middle.
| | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | EdPruss is right. The radiator mounts on the rear of the frame and then it's offset towards the front by an inch so the radiator sits in the middle of the frame. The new radiator I bought has the mounting flange in the middle of the radiator.
Fixit1958, I'm curious if you have the same setup in your truck. What type of fan arrangement do you have? I'm thinking I could leave the fan off and install an electric pusher fan but really don't want to go this route. | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | RedGreen,
I have the stock set-up in my '49. 216 cu.in. with stock water pump and fan. As I said, I have not yet installed the KKS radiator, but I will be taking on that task real soon. I will let you know if I run into the same problem, or if mine slips right into place. When I measured my original radiator against the KKS unit it all measured out the same...or seemed to. I will let you know what difficulties I run into.
Tim
| | | | | Joined: Dec 2005 Posts: 257 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 257 | I'm still trying to piece this readiator mystery together, so I've been scouring the gallery pages to see original setups and found this picture of Jon Miller's engine compartment. http://www.stovebolt.com/gallery/images/miller_jon_1950d.jpgThe radiator flange is in the middle of the radiator. As I mentioned before mine is offset by at least and inch. Which means someone in the past changed that. That makes more sense because the cross braces have been cut out of the radiator support. He must have done that when he installed the 235 with a long shaft water pump. Now everything is new on the engine including a short shaft water pump. So I should have plenty of room for the radiator. But I don't. Hmph. I guess I'll bedoing some more head-scratching this weekend while looking in the engine bay. | | |
