10 members (Otto Skorzeny, 49fastback, jmoore, HandyAndy, Rusty Heaps, Joe H, GMCJammer51, 66flea, 68ironhead, Cosmo), 94 guests, and 2 robots.
Topics128,035
Posts1,055,570
#1133876 11/11/2015 5:10 AM
I bought an HEI distributor for a small block. Now when the engine accelerates it stumbles. I watched the timing while reving the engine and noticed the vacuum advance retarded the timing, the engines stumbles and the centrifugal advance then advances the timing. Anyone ever experienced this before?
You may have the distributor vacuum hose at the wrong port on the carb.
I found out that some of the HEI distributors use the vacuum assembly to slightly retard the timing when the vacuum falls. This is designed to some how enhance power when the vacuum falls. I don't understand it, just read it!
I will have to tackle this very problem soon. I have a 1970-something Pontiac Q-jet Carburetor on a Chevrolet 350 and have to figure out where to put that vacuum line.
