| | | Forums66 Topics128,110 Posts1,056,251 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 79 | I have a 1950 3100 with 216 it has a sediment on top of the fuel pump I want to clean it out. I unscrewed the knob knob on top to flip the wire bail out of the way but the glass bowl does not want to move is it just stuck or did I miss something?
Also if the bowl is removed does the tank fuel value need to be closed or does the fuel pump prevent gas from flowing from the tank
1953 3100
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Yes, closing the tank valve is a good idea.
It is just stuck. Give it a tap sideways with a block of wood or a plastic hammer | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | You most likely have a gasket that is stuck. Tap on the bowl lightly with a plastic hammer from the side and it should break free. Be prepared to replace that gasket. Edit...Jim beat me to it.
| | | | | Joined: Nov 2014 Posts: 79 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 79 | great thanks for the replies
1953 3100
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Cletus1950,
The glass fuel bowl is stuck to the cork gasket. Carefully take a small screw driver and pry up on the glass bowl to remove it. You will probably need a new cork gasket which are available with most of the early Chevrolet truck vendors or E-Pay. Shut off the fuel tank valve before you remove the glass bowl to help prevent further gasoline leakage at the pump. That's the way I do it, but some may disagree about the fuel shut off valve at the tank? Hope this helps.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
