8 members (Gdads51, frogfarmer, Wayne67vert, sron48, dt235sd, cmayna, Scott, 48jim1ton), 128 guests, and 0 robots.
Topics128,043
Posts1,055,540
Members48,425
#1134875 11/18/2015 3:48 AM
I have a 1954-1961 GMC 270 motor in a 1949 chevy coe. I have put a carburetor kit in the Zenith carb. without any success...maybe some one can tell me who bebuilds zenith carb's, or what to replace it with? Thanks
Zenith still builds Zenith carbs, check if they have a suitable replacement. I just installed a new down draft Zenith on a GMC, running night and day better than the old one that had recently been "rebuilt".
1952 Chevrolet 3800 pickup
---All pictures---
coeleo & Grigg,
Please let us know if you find new Zenith replacement updraft carburetors for a 270.
I think I have seen it somewhere, but I cannot find a link.
The nearest I see on Zenith's website is listed as suiting up to 250 CID, so might limit top end power on a 270. Hopefully someone with better knowledge can advise on any limits.
http://www.zenithfuelsystems.com/updraft_267.htm
The carb to manifold flanges and studs might also be an issue to check
Nonetheless, they show a 228. What is the price?
I put in a call to the local distributor who will call Zenith and then get back to me. He said Zenith is sometimes a little slow, might not get an immediate answer.
Grigg
---All pictures---
Ouch!
Zenith says part numbers 14475 and 11280 are no longer available.
Number 14275 is available but cost $962.67 through Fisher Autoparts in Roanoke, VA
That part number should work with 228, 248, and 270 engines.
Searching online I had seen prices mentioned in the $600 range as well as one on ebay at $890obo.
Perhaps another dealer/distributor can get/offer better prices, or has older stock that was purchased at more favorable prices.
Again, this is all for downdraft Zenith model 228, not updraft
Grigg
---All pictures---
V
VEW Offline
V Offline
I've had a local shop rebuild several carbs for me over the years with excellent results. They rebuilt an updraft carb for Doughboy (235). The also do business through USPS. If you would like their contact info, let me know; or you can look them up.
K&K
Frederick, MD
~ Victor
1957 3100 - moved on
VEW #1135009 11/19/2015 3:14 AM
Yes, I would be interested in contacting your carburetor; rebuilder. Thanks coe leo
back yard wrench turner
W Online: Content
I just had my Zenith rebuilt for a GMC 270 cu inch motor. I used National Carburetor
It was $175 with FL state tax. Turn around time was 12 days.
It came back looking like new. They even replaced the lower part of the carb.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Wayne,
Thanks for that information.
coeleo #1135121 11/19/2015 11:38 PM
W Online: Content
I hope it helps many others that need their carbs rebuilt.
Wayne
1989 Silverado
coeleo #1135122 11/19/2015 11:40 PM
I contacted National Carburetor:
~$200 plus shipping for rebuilding my 270 updraft Zenith carburetor. That might include return shipping.
"We could build yours if you have one to send in.
$199.95"
W Online: Content
My price included return freight.
Wayne
1989 Silverado
Wayne,
They gave you the home state discount.
I got the New York snow bird special price?
W Online: Content
Tim, my carb is a standard downdraft 1 barrel.
1 barrel antique carburetor
$149 plus shipping plus state tax = $176.xx
Wayne
1989 Silverado
OK, thanks, Wayne
I thought it might have been an updraft in response to the original post.
Did they paint the body or cadmium/etc plate the body?
W Online: Content
Tim,
the upper body is clean like new, the lower part is coated like a grey color. I think they replace the lower part since it was leaking fuel.
Wayne
1989 Silverado
V
VEW Offline
V Offline
For those interested:
K&K
Frederick, MD
(301) 663-5258
~ Victor
I've owned about 50 Chev & GMC COEs. I think the 54 350 is the only yr that the air inlet faces forward. I'd have to check part and service manuals to see. The Chev faces forward but uses a Carter only for 54 & E55. I've that NOS in OE box.
