| | | Forums66 Topics128,148 Posts1,056,810 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 67 | I have both any body do this swap? I'm considering any thoughts? | | | | | Joined: Mar 2004 Posts: 6,228 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,228 | What year 2-ton??? Mike B  | | | | | Joined: Oct 2015 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 67 | 49 Chevy 2 ton. Plan 6 bt swap need better front end or frame | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | It depends what you're wanting. The track of the 94 will be pretty wide, so you'll end up with a stock or wider stance on the front of the 49. It can be done.
Do you have any specific questions? Your inquiry is a bit vague to give any useful information. | | | | | Joined: Oct 2015 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 67 | I'm currently struggling with keep original frame and figure out brakes. Or switch to a different frame. I'm building a truck with 6 bt cummins to pull 10 k of machinery for my work. So I want safe first then power and looks | | | | | Joined: Oct 2015 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 67 | The 5 in h wider track doesn't bother from what I've seen. | | | | | Joined: Oct 2015 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 67 | I think I've found my solution. I found a old motor home with an IFS under it. The frame on it is two inches wider. I think I might do a frame graft or graft frame in under existing frame | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | If you want to pull 10K of machinery and that is your main goal, I suggest you use a complete frame from something that is factory designed to carry that kind of wait. Just less variables that way. | | |
