7 members (klhansen, Peggy M, Cletus1950, TUTS 59, papas52, Bill Hanlon, 1 invisible), 89 guests, and 3 robots.
Topics128,172
Posts1,057,038
Members48,458
#1134404 11/15/2015 3:05 PM
I have both any body do this swap? I'm considering any thoughts?
29 Ford
http://s1078.photobucket.com/user/c...4-BF50-713F5EDE5632_zps8zoj9vfq.jpg.html
31 Ford
55 panel
95 4 door power stroke
49 chevy 2 ton
47 2 ton grain bed w/ hoist.
Many trucks waiting
What year 2-ton???
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
49 Chevy 2 ton. Plan 6 bt swap need better front end or frame
29 Ford
31 Ford
55 panel
49 chevy 2 ton
Many trucks waiting
It depends what you're wanting. The track of the 94 will be pretty wide, so you'll end up with a stock or wider stance on the front of the 49. It can be done.
Do you have any specific questions? Your inquiry is a bit vague to give any useful information.
My 46 GMC on Photobucket
I'm currently struggling with keep original frame and figure out brakes. Or switch to a different frame. I'm building a truck with 6 bt cummins to pull 10 k of machinery for my work. So I want safe first then power and looks
29 Ford
31 Ford
55 panel
49 chevy 2 ton
Many trucks waiting
The 5 in h wider track doesn't bother from what I've seen.
29 Ford
31 Ford
55 panel
49 chevy 2 ton
Many trucks waiting
I think I've found my solution. I found a old motor home with an IFS under it. The frame on it is two inches wider. I think I might do a frame graft or graft frame in under existing frame
29 Ford
31 Ford
55 panel
49 chevy 2 ton
Many trucks waiting
If you want to pull 10K of machinery and that is your main goal, I suggest you use a complete frame from something that is factory designed to carry that kind of wait. Just less variables that way.
