0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 55 | I have a very nice totally stock 59 apache Short fleetside, with a 4 speed .only changes I want to make to it ,would be a seat from a 88- 98 chevy truck ,but most of all I want air conditioning, my ??? I have a nice rebuilt 292 that would be a sweet engine for it, but will lose the stock engine bay, will the stock 235 with A C be Ok ? Also might want P'S someday ? I really like stock, but ? Just want your 2 cents opinion? Thanks from a new Stovebolter
59 chevy apache fleetside
2007 dodge diesel 84 toyota 4 runner, v8,propane power
| | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | Here's my 2-cents: I, too, have a stock 59 Apache with a 4-speed and six cylinder. With the stock steering wheel and bias ply tires, I haven't had any difficulty with the steering and haven't considered adding power steering.
As for the seat, I'm glad I have the original one. It's got quite a bit of spring and absorbs some of the bumps, almost making it part of the suspension. With the solid front axle, you may find 88-98 seats a bit firm.
Bob
1959 Chevy Apache Short Bed Step Side 1967 Cadillac DeVille Convertible 1967 Pontiac Firebird Convertible
| | | | | Joined: Oct 2015 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 55 | thank you , Ijust need a little more room behind the steering wheel ,,I just need a seat with , not as wide back rest ,,stock seat (backrest )somehow modified would work ,I"ve searched ,no info for that ???
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | S-10 seats are thin?
| | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | 292 is a very good swap if you want AC and PS at a later date. 235 is harder to add those to and still have enough power to get into traffic. | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | I added A/C to my '57 with a stock 235 and a 4 speed. No problems.
I have the stock steering wheel and 19.5" tires. I don't have any problem with the manual steering. I do have a suicide knob on the wheel and find it very helpful, particularly when backing up.
I have the stock seat but felt cramped with my long legs. The seat can easily be raised about 2 1/2" with spacers made from 1/2" iron pipe. Doing this made it much more comfortable for me...no more feeling cramped. | | | | | Joined: Oct 2015 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 55 | thanks guys , that's the info I needed , I will try raising the seat ,hope that works , will leave the 235 in 4 now , will put ac on that motor , That would be great ! but I do have that nice 292 looking at me everyday ? More of your 2 cents wanted
| | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Here is a picture of the 1/2" pipe spacers that act as posts to raise the seat. I inserted nylon spacers (available at any hardware store) into the posts to keep the new, longer bolts dead center. I recommend using fender washers at the top and bottom of the posts to spread the load. http://s844.photobucket.com/user/ma...%20spacers/IMG_1135_zpsv5nl5bby.jpg.html | | | | | Joined: Oct 2015 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 55 | Thank you , I will try that ! ?? HOW DID YOU MOUNT that Ac ? Did you upgrade you generator? How about your radiator ? Pulley on balancer ? I Gotta know ?
| | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Here are some pix of the A/C. http://s844.photobucket.com/user/ma...2911_zpsda0c7c1c.jpg.html?sort=3&o=0The evaporator/blower is mounted under the seat. The controls fit into the ashtray opening. Relays and fuses mount under the dash. The condenser and two 9" pusher fans fit between the grill and the radiator. I upgraded to a 3 wire 10SI alternator. The A/C and alternator run on one belt off the crankshaft pulley. The radiator was fine. I converted from the original 4 blade fan to a 6 blade. I added the two pusher fans mentioned above, but that was more to circulate more air through the condenser than it was to cool the engine. I also added an idle stop solenoid to bump the idle when the A/C is turned on. Matt | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | They're also narrow. The 88-98 truck seat is a better fit. That said, the OP could easily make a foam back for the seat that is thinner than the stock spring set. | | | | | Joined: Oct 2015 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 55 | thanks guy , I found a bench seat r from a 88 chevy single cab ( $50 ) from pick pull )last of old school design seat ,no head rest ,no 60,40 ,also no special cutout on the bottom foam for each person ( my is flat from one side to the other side ) gotta check ? three different types out there ! my 2 cents
| | | | | Joined: Oct 2015 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 55 | ok guys here are my pics truck pics
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Nice Fleetside! Mike B  | | |
