| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 187 'Bolter | | 'Bolter Joined: May 2011 Posts: 187 | Jimbo 24,
There is a brace that holds up the front end of the apron on the inside. It's made from what looks like 16 gauge sheet metal and kind of follows the curve of the apron. It does not attach to the bed panel at all. They are the same brace that is used on the 1/2 & 3/4 tons. I have not seen these sold separately, but usually are sold with the new aprons. It doesn't look like a difficult piece to make either. Look thru some project pictures and I'm sure you can find what it looks like, or maybe someone in the forum has a picture they can post. Good luck! Tom
| | | | | Joined: Jul 2013 Posts: 363 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 363 | r u talking about the one that is attached to running board | | | | | Joined: May 2011 Posts: 187 'Bolter | | 'Bolter Joined: May 2011 Posts: 187 | That's the one, I think there is a square hole in the running board for that connection. Kind of a special head carriage bolt that goes there. Mine were actually too far gone to use, I still have them for patterns, just have not made any yet. | | |
