0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
#11347 03/28/2005 3:28 AM
I just learned that early 1950s Chev cars with Powerglide have torque tubes. If that is so how does the u-joint get lubricated in the ball housing? Is it ATF or something else? Are there bushings and sals in the torque tube to keep fluid from reaching the diff?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#11348 03/28/2005 4:44 AM
I have a 54 Powerglide, and I assume that the 50 is similar. There is a needle mechanism that meters AFT from the transmission into the U-Joint area. And there are bushings and at least one seal to keep the ATF from the differential.
In fact, my metering needle is stuck, and I need to fix - if you find any info on the needle assy please forward it to me!
Loosening the U-Joint ball housing should release some ATF if the lube system is working.
From what I've read, an 'oakie bushing' is the preferred bushing replacement. I figure to replace this as well when I get the driveline apart to fix the needle.
