2 members (78buckshot, 1 invisible),
390
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2001 Posts: 31 | Can I put a 1938 pressure plate in a 1937 1/2 ton? My 37 has a coil spring pressure plate (10" diameter). The 38 is diaphragm with a 9" clutch plate. Do I need to change the clutch plate? The 37 is a 10" plate. The 38 is a 9" plate. Both fit on the flywheel plate fine. The coil spring pressure plate does not engage smoothly.
Mike J 37 GMC
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Unless you are planning on changing to a 1938 bellhousing, clutch fork, throwout bearing, flywheel, pressure plate and disc, you will find this a no go.
See the USA in your vintage Chevrolet! My Blog | | |
