8 members (HandyAndy, Hotrod Lincoln, baldeagle, Jon G, TexasA&M48Truck, MickeyP, cmayna, 1955 1 Series), 72 guests, and 7 robots.
Topics128,022
Posts1,055,352
Members48,420
#1134350 11/15/2015 1:16 AM
Gang I am looking for the stock style Panhard mount for the axle side. Doing a rearend swap on my 63 C10. I would rather not cut the one off the axle I am removing.
Thanks for your help
Scott,
Way back when there was a bunch of articles about doing this.
I cannot remember the magazine but a search on the internet led me to this site:
http://webrodder.com/articles?search=six+pack+to+go
The one you want to look at for this job is:
http://webrodder.com/article/six-pack-to-go-part-6-converting-a-late-12-bolt-for-trailing-arm
I can't remember the exact date but I did this exact thing probably 15 years ago (I had the actual magazine it was printed in).
If you do not want to mess with your original rear end I guess you could get a spare to work on.
Bottom line, I do not know of anyone who sells this bracket. Maybe you could get 4-5-6 Chevy to get you one but you would have to contact him personally as I do not know.
thanks for the lead!
As a heads up: I believe GM changed the design of the panhard bars (3) times during the 60-66 C10 run:
* 1960-1962 utilized a 33" bar length
* 1963-1964 utilized a 27" bar length
* 1965-1966 utilized a 24" bar length
Bar length and mounting to the axle changed.
Measure thrice... buy once.
And FWIW.... Here is a tech article I authored back in 2011 related to track bars: http://talk.classicparts.com/threads/track-bars-the-short-and-the-long-of-it.14368/
_____
John thumbs_up
Scott 657
I have one of those stock bars---out of a early 60's short, fleetside, C-10.
It is still on the frame & empty axle housing (was a box trailer when I got it years ago)--- Pm me if you are interested.
I saved the bed but the rest is heading for the crusher someday.
It is free to you if you cover the shipping expense.
delky dave in WYO
1957, 3100, v8
2016 gmc 4wd
I sent a PM
Unconventional Thinker
_____
John thumbs_up
I have an axle from a '68 that I put my old '65 Mean Green, and the panhard bar on it is a different design and so is the axle. Besides the axle being a Dana 60, the mount appears to be part of the axle assembly and not welded on. It also comes off at a different angle. They can be swapped in but the mount on the frame needs to be altered/relocated.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
