0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | How long a shelf life does engine oil have??? Or does it last forever??? Which is a very long time.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Unopened it should last a very very long time. It's enemy is oxygen. Most oil companies will tell you five years just to cover their rear end. Straight 10w is hard to find now a days, but I've got a bottle of it that I use to fill oil cans. I've had it for about 40 years. Still looks and acts like 10w oil when I pump it out of the oil can. It does have a lid but so its been exposed to the atmosphere, still it looks OK. I would look for sediment settling to the bottom a cloudy look to it or rancid smell before I would not use it in a Stovebolt. It's my understanding that the additives tend to settle out of a blended oil. So if it's a straight weight I'd say it good for your life time. Jerry should be along in the morning to give us the real skinny. http://www.pbase.com/dennygraham/image/161854703/largehttp://www.pbase.com/dennygraham/image/161854702/largedg
Denny G Sandwich, IL
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I found a full case of old unused oil at my dad's house a few weeks ago, don't know the age of it but it could easily be well over 10 years. I put it in my 5.3 and am keeping a close eye on it. So far, so good. One of the factors to consider might be that today's oils are superior to the older stuff, but I figure that if it worked fine then, it should still be okay. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I have a few cases of un opened "OLD" multi grade oil. When I use it, it seems to be cloudy at the end of pouring it out. I was wondering if the additives were settling out of it, and it wouldn't be safe using it.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Brian,
That is a good question. Are there any particulates?
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Tim, there appeared to be some on the bottom of the container.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think I would not use it in an engine. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I thought this line in you Valvoline link answered that question. "If the rating is still current, we advise you shake the container before use to blend any additives that may have settled."
dg
What is the brand and grade/rating of your "OLD" multi grade oil.
Also, try shaking the oil and then filter the oil. Look for particulates on the filter.
If I found particulates on the filter, I think I would not use the oil. | | | | | Joined: May 2009 Posts: 85 'Bolter | | 'Bolter Joined: May 2009 Posts: 85 | Pretty interesting guys, I always just assumed that little bit of milkiness was a bit of condensation or moisture of some kind, so I just stopped pouring a little early. Guess I was missing some of the good stuff!!! I'll have to try shaking the container next time.
1949 3100
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | If you poured the whole can into the engine, wouldn't the engine mix it back up as soon as you ran it? | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Here ya go Tim.
Citgo---SL, SG Citgo---SM, SL, GF3, GF4 Valvoline---SJ, SH, GF1 GF2 Exon--- SL, SJ, SH, SG, GF3 Quaker State---SM, GF3, GF4 BIG A---SJ, SH, GF1, GF2 NAPA--- SM, SL, GF1, GF2, GF3, GF4
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you poured the whole can into the engine, wouldn't the engine mix it back up as soon as you ran it? Most likely the oil will mix OK, as long as there are no particulates that will not go back into "solution". There might be no particulates, unless something changed in the oil's composition while it was sitting/aging. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Brian, All those oils have modern specs (and meet older specs). By the way, are the GF* specs actually CF* specs? http://www.oilspecifications.org/api_eolcs.php | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Tim, went out to the garage this morning with my glasses and flash light. It reads GF on all the different brands.
