8 members (Gdads51, frogfarmer, Bill Hanlon, LAROKE, gswbbc, Forty9, 48jim1ton, Hotrod Lincoln), 107 guests, and 0 robots.
Topics128,043
Posts1,055,540
Members48,425
#1134169 11/13/2015 3:47 PM
I have read that the bell housing from a 216 will bolt right up to a 235. I know the flywheel from the 235 is larger than the one from the 216, but will it work with the 216 bell housing?
twheelock #1134173 11/13/2015 4:06 PM
Yes
I do not think that the diameter of the flywheels are different. 216 and 235 and 261 flywheels will bolt up to any of those engines, and any of those flywheels will fit into the clutch housings for any of those engines (if I am incorrect, someone will correct/clarify).
The number of teeth on a 6v vs 12v flywheel (and 6v s 12v starter) are different. The shape of the teeth on 6v and 12v starters are different
The diameter of clutch/pressure-plates might be different.
The length of the clutch release (throwout) bearing matches the pressure plate.
twheelock #1134184 11/13/2015 5:34 PM
Thanks for the info!
twheelock #1134185 11/13/2015 5:36 PM
Issue re. the early bell housing is that older 216 housing may accept the later flywheel BUT later model pressure plate may not fit inside the older housing. This happened to a friend of mine with his '37.
1946 1/2-Ton Chevy
twheelock #1134190 11/13/2015 5:58 PM
1942-62 flywheels will all bolt to the crank, and are the same diameter. As mentioned above a 11" pressure plate and clutch will not fit in all bellhousing.
My Blog
