1 members (JW51),
137
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | will a 1952 Axel shaft fit my 1955 HO33 gm cor-pet rear end thank you Bill | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 55 GMC, according to my Canadian parts book the axles for a 1951-55 1/2 ton rear axle are the same, hope that helps. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | My Hollander manual agrees with Bobb's book. | | | | | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | thank you Bob & cletis I will install the 51-52 parts in my 55.2 | | |
