0 members (), 61 guests, and 1 robot.
Topics128,049
Posts1,055,743
Junior Member
Junior Member
I'm in the process of removing my sidewindows from my 52 3/4 chev pu.
I have everything disconnected except for the wing window post that goes down into the door. There seems to be a standard slotted screw holding the post in place. Is this correct? I tried turning it with a big screw driver and it won't budge. I can't see what is there, but I can feel it. I don't feel a nut on the other side. It must be a permanent type of nut.
Any suggestions on how to get this off? I didn't try too hard as I didn't want to strip the screw.
Thanks for any help
Mike
Mike, I had a hard time getting the vent assenblies out as well. Seems years of sitting outside rusted that bottom bolt solid to the captive nut, and even after soaking in PB-blaster it wasn't budging. I got my entire arm inside the door and could feel the bracket try to twist off as I applied torque to the bolt.
Finally, I drilled a hole in the inner doorskin and cut a tab directly over the offending bolt. With a bit of the skin peeled I could grab the bracket w/ vice grips and hold it while I torched and twisted the bolt free. Once I got it out of there, I tapped the doorskin back flat and slapped some fiberglass over the hole.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
