1 members (baldeagle), 37 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#1133838 11/11/2015 1:08 AM
First post I put in the wrong section. So looking at the back of the ammeter which post is "+" and which is "-"? I have looked at 2 different diagrams and they are both different. Stock gauges 53 3100 root
root #1133843 11/11/2015 1:36 AM
An ammeter doesn't have a plus and minus. An ammeter is placed in line. If you ground one side you have a direct short to ground.
root #1133847 11/11/2015 1:59 AM
The ammeter does have a positive and negative post, but if it's connected backwards, it just reads "discharge" instead of "charge" as the generator/alternator output goes to the battery. The direction the current flows will depend on whether the vehicle is positive or negative ground. If the reading is backwards, just reverse the leads at the back of the ammeter.
Be sure all the "load" connections such as the supply wires to the ignition switch, headlight switch, etc., and the charging device output are all connected to the downstream side, and the only wire connected to the other side goes to the battery cable attached to the starter. If accessory wires are connected to the BAT side, the meter will not read charge/discharge accurately.
root #1134239 11/14/2015 2:35 AM
Looks like I have one to many on the plus side will fix this weekend. Thanks all for the help. root
