1 members (joe apple),
110
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 | Any tips on how to clean out the brake fluid from the entire truck. I am looking to give it a fresh start.
Thanks for the time.
Scott M.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | scooter m.,
Follow the standard bleeding procedure (assuming you are referring to a 1/2-1 ton 1954 truck with standard/original-style brakes).
Run a lot of new/clean standard brake fluid through each wheel cylinder (starting at the wheel cylinder furthest away from the master cylinder).
LR - RR - LF - RF
Go through the wheel-cylinder cycle twice - it will not hurt anything. | | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 |
Scott M.
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Don't forget to fill the master cylinder often. It seems to only hold a thimbleful. Another option is to use a pressure bleeder made out of a cheap hand pump pesticide sprayer. You can Google pressure bleeder and see several to get an idea on how to make one yourself real cheap. I drilled and tapped a spare master cylinder cap to accept a threaded nipple for the plastic tubing. You will need to plug the two vent holes in the side of original cap. I welded them shut. Carl
Scott M.
| | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 | Hoping someone might give me a breakdown of how to do a brake adjustment as well. Thanks so much for the time everyone.
Scott M.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | scooter m., Do you have a 1954 Truck Shop Manual? Or, have you looked at 1954 brake adjustment description that is on-line? You might want to read about brake adjustment and then post any questions that you have. Be sure to describe your truck: 1954 Chevrolet 3/4 ton with stock-style brakes? | | | | | Joined: Dec 2014 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2014 Posts: 49 | Thanks a lot Tim. I'll be sure to be more clear going forward.
Scott M.
