5 members (Otto Skorzeny, Southerntruck, Guitplayer, Hotrod Lincoln, 52Carl), 119 guests, and 3 robots.
Topics128,087
Posts1,056,119
Members48,435
Any tips on how to clean out the brake fluid from the entire truck. I am looking to give it a fresh start.
Thanks for the time.
Scott M.
scooter m.,
Follow the standard bleeding procedure (assuming you are referring to a 1/2-1 ton 1954 truck with standard/original-style brakes).
Run a lot of new/clean standard brake fluid through each wheel cylinder (starting at the wheel cylinder furthest away from the master cylinder).
LR - RR - LF - RF
Go through the wheel-cylinder cycle twice - it will not hurt anything.
Thanks Tim!
Scott M.
5 Online: Content
Don't forget to fill the master cylinder often. It seems to only hold a thimbleful.
Another option is to use a pressure bleeder made out of a cheap hand pump pesticide sprayer. You can Google pressure bleeder and see several to get an idea on how to make one yourself real cheap. I drilled and tapped a spare master cylinder cap to accept a threaded nipple for the plastic tubing. You will need to plug the two vent holes in the side of original cap. I welded them shut.
Carl
Thanks for the tip Carl.
Scott M.
Hoping someone might give me a breakdown of how to do a brake adjustment as well. Thanks so much for the time everyone.
Scott M.
scooter m.,
Do you have a 1954 Truck Shop Manual?
Or, have you looked at 1954 brake adjustment description that is on-line?
You might want to read about brake adjustment and then post any questions that you have.
Be sure to describe your truck: 1954 Chevrolet 3/4 ton with stock-style brakes?
Thanks a lot Tim. I'll be sure to be more clear going forward.
Scott M.
