2 members (artinva, Chip O),
112
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 63 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 63 | Rewiring my 55.2 and today I did a quick test on the heater switch... The 2 ceramic(?) resistors(?) on the top of the switch got pretty darn hot.. the motor is 12 volts.. do these normally get hot? the motor ran fine on all 3 settings. .... see pics here Heater Switch & Motor Thanks!
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | normal for those wire wound resistors to get hot enough to glow red and take the skin off your fingers, just make sure any flammables are kept clear
Bill | | | | | Joined: Aug 2012 Posts: 63 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 63 | Thanks Bill! Just never touched one while it was running.... My finger tips thank you!
DJ
