1 members (Materman),
115
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | I am replacing my water pump and the new one I purchased has a small hole at the top left looking from the front that intersects with a hole in the block. The old pump didn't have this hole,which one is correct?another question I have is the water pump has 2 - 3/4 inch hose fittings and the thermo housing has one,I realize 2 of these go to the Heater circuit but what about the third one,the cylinder head was off when I purchased the truck,and I didn't see how it was plumbed.
1962 GMC 920 step side 261 4 spd
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | This is a '59 261 pump and thermostat hsg. I don't know which truck or bus this came out of so can't tell you the routing of the hoses. http://www.pbase.com/dennygraham/image/161809621/largedg
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Denny,
Have you checked the operation of the thermostat (a Dole pellet by-pass thermostat was originally used, I think)?
GMC kid 7530,
My 1960 261's water pump (from a school bus) did not look like Denny's. It had an extra port (or two); and, the thermostat housing had a port on the bottom, like Denny's.
Years ago, someone posted the purpose for those ports (sqeeze or 3B or Mike B?) - a by-pass hose. I wildly guessed they were for a heater at the rear of the bus (or, maybe for a transmission warmer/cooler).
Maybe someone will post an answer?
You may plug the holes if they are not used (mine were plugged with hex-head steel plugs).
Years ago, I used a smaller truck's water pump and thermostat housing, to better match my 1954 radiator. Today, I use a water pump relocation plate and a 54 water pump and thermostat housing. | | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Denny, I believe the GMC 228 had this type of water pump set-up.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
