0 members (), 116 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1133241 11/07/2015 12:34 AM
Having a braking issue with my 1950 1/2 ton. Prior to changing a leaky brake cylinder on a rear wheel I started to have a problem when I applied my brakes. I would have to pump it a couple times to get proper brake pressure. It would be ok and hold but the next time I come to brake I would have to do the same thing. Not the safest thing on this single brake master cylinder system. I changed the leaky cylinder and bled the system. Still had the spongy brake problem so I put a kit in the master cylinder and bled the system. I still have the same problem with the brake needing to be pumped to get pressure. Could it still be air in the system? Anyone else with this problem? Open to all suggestions. Keep on truckin. Dan V
danv #1133243 11/07/2015 12:42 AM
What procedure did you follow when adjusting brake shoes?
danv #1133246 11/07/2015 12:50 AM
I adjusted the shoes with the wheels off. Turned the hub until it was starting to catch and backed if off slightly. Maybe I did not explain myself well enough. The brake pedal gets little to no resistance until you pump the pedal. Once it pressures up it holds OK until the next time you come to brake.
danv #1133249 11/07/2015 12:55 AM
danv #1133260 11/07/2015 1:48 AM
You still have air in the system. Pumping the breaks until they hold is due the gradual compression of the air in the line until it has compressed to the point where enough pressure is exerted on the brake shoes to hold the drums. Look for leaks everywhere.
Carl
danv #1133328 11/07/2015 4:08 PM
I would think that if your problem is air, it will feel like you are pushing on a spring. If it takes one extra quick pump and the pedal is firm, it is an adjustment problem.
1951 1 Ton Completed
danv #1133738 11/10/2015 5:00 AM
Riding in the Passing Lane
There are 2 adjustments on each wheel. They are all right hand threads. Adjust each one till you get a heavy drag. Then back it off about 4 notches. You may still get a little drag but that's ok.
1972 Chevy c10 Cheyenne Super
danv #1134673 11/17/2015 12:42 AM
Thanks guys.
