2 members (Ponchogl, Hush),
67
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 41 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 41 | Hey all, I just looked over and drove a '58 3100 and the owner said it did not have a stock rear end. So I crawled under her and found a 12 bolt dif with "k 1440" cast in at the 5 o'clock postion. The case also has what appears is a lifting hole cast into it at the 2 o'clock postion. I've never seen this and I'm new to the task force trucks. It has tall gears for higher speed but what is it? The owner has no clue either.
Shoe | | | | | Joined: Aug 2012 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 28 | Most likely a pickup coil spring 12 bolt from mid to late sixties. The hole is where the locating strut mounted.
1954 GMC 9314 - 261 t5
| | | | | Joined: Dec 2013 Posts: 41 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 41 | Locating strut? This looks nothing like a '60's dana 44. The hole is about 1 1/4", cast into the case like an old moonshine jug handle. I've googled k 1440 and have come up empty.
| | | | | Joined: Dec 2013 Posts: 41 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 41 | OK, I found a pic online. It looks like a 8.875" GM12T truck dif from the late 60's to '80's, still don't know why a strut would be mounted there for.
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Panhard bar. Used in the coil suspended 1/2 and 3/4 ton trucks. Was used to keep that rear end from moving side to side. The trailing arms would keep it from "wrapping" up under load. Look a bit like this? http://67-72chevytrucks.com/vboard/attachment.php?attachmentid=682734&d=1295146476Was a common thing on the coil suspended trucks.
Steve H
| | | | | Joined: Dec 2013 Posts: 41 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 41 | Thanks, exactly! What does k1440 indicate? | | |
