2 members (NJC, greenie-reddy),
159
Mod | | | Forums66 Topics128,260 Posts1,058,287 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I recently purchased a new key cylinder and keys for my truck (1956-3200). The door locks fine from the inside but the key doesn’t turn in the lock from the outside. I pulled off the door panel but for the life of me cannot see how to get enough room for my hand in the access hole to unscrew the door handle. The manual doesn’t address taking off the door regulator to remove the door handle. I didn’t see anything on the site search here specifically dealing with this. Please forgive such a basic question but is it common to remove the door regulator and door lock mechanism itself in order to get to the handle? Thanks, Mark
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I don't recall any problems changing the handles on my '56. And I don't recall having to worm my hand into an access hole. Perhaps I used a longer screwdriver. | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | You've confirmed my problem. I have big hands and a limited selection of screwdrivers. | | | | | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | It took a little struggling in a tight space but I got it out. | | |
