2 members (ronsway, Nick in Manitou), 108 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#1132746 11/03/2015 9:29 PM
When I replaced this item, it was about 1/8" above the lip of the mast and did want to push in further. Is the bearing supposed to be completely flush with the mast? I did not want to force it if not necessary. Thanks, Steve
Steve,
Yes it should be flush with the top of the steering mast. I put a thin coat of dielectric grease on the bushing and pressed it in.
Tim
1970 VW Beetle
Thanks Tim. I should have thought of that first
I suppose the thing to do now would be trying to press it the rest of the way in. The shop manual shows tapping it in with something that resembles a large socket. Maybe a few drops of 3in1 oil around the perimeter would help?
3-in-1 oil sounds good
Be careful using any "grease" that might contain silicone. Silicone will contaminate surfaces that might later need to be painted.
Tim thanks for that tip. Because of this forum, I avoid using products containing silicone.
