| | | Forums66 Topics128,130 Posts1,056,370 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | When I replaced this item, it was about 1/8" above the lip of the mast and did want to push in further. Is the bearing supposed to be completely flush with the mast? I did not want to force it if not necessary. Thanks, Steve | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Steve,
Yes it should be flush with the top of the steering mast. I put a thin coat of dielectric grease on the bushing and pressed it in.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Thanks Tim. I should have thought of that first | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I suppose the thing to do now would be trying to press it the rest of the way in. The shop manual shows tapping it in with something that resembles a large socket. Maybe a few drops of 3in1 oil around the perimeter would help? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3-in-1 oil sounds good
Be careful using any "grease" that might contain silicone. Silicone will contaminate surfaces that might later need to be painted. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | Tim thanks for that tip. Because of this forum, I avoid using products containing silicone. | | |
