| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 67 | 49 6400. This is my first big bolt. I plan to put in a 5.9 cummins. Brakes ps. This truck I plan to haul machinery. Im in construction and want a toy machine hauler. I want smaller wheels tires . I will really consider this size of truck to 3/4 ton in modern time. Help me | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Chuck malone, welcome, by what you wrote it looks like you really want a modern truck with an older style body on it. It would probably be easier to mount an old body on a more modern chassis with whatever running gear you prefer rather than make a lot of modifications to an older chassis that will take a lot of time and re-engineering. I realize this suggestion may sound harsh but I'm trying to be practical with my suggestions, hope that helps. | | | | | Joined: Oct 2015 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 67 | I've already done that I'm looking for alttle more of a challenge . Like to stay original looking I like the frame shape. And I have a year to kill. So here I go. I'll post some pics of of where I'm at and the progress I've made. Hope to revive some tips on my journey. | | | | | Joined: Oct 2015 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 67 | I've done a 3100 on a s-10 that frame is too small for my needs. But I'm open also to a frame change if I decide to go that route. Just need ideal of what would be a good donor | | | | | Joined: Oct 2015 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 67 | What is the rating of 3/4 ton front axle. | | |
