2 members (lumbersawyer, klhansen), 75 guests, and 0 robots.
Topics128,047
Posts1,055,538
Members48,424
#1131856 10/29/2015 2:41 PM
Hi All,
Does anyone have pictures of trucks with a spot light or dummy light. Not sure what the correct term is. My truck has 1950 AD has always had the hole for a spot light. I would like to see what it should look like especially in the interior, like does it get in the way of turning the steering wheel because it extends in the cab too far?
Did they come from the factory with them installed? What size or brand would they have been?
skipper
rc356s #1131866 10/29/2015 2:55 PM
I have a few pics here
...link...
I used an existing hole in the truck that was not drilled correctly. so I had to compensate on the exterior mount.
rc356s #1131971 10/30/2015 1:30 AM
rc356s if you use the correct Guide S-6 that is 18 inches it will not extend in the cab too far. Here is a picture . The drill walked a little on on the inside however not bad Guide is still in business and has parts and tech support. PM me if I can help.
Mtneermike
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
rc356s #1132065 10/30/2015 2:43 PM
Thanks for the pictures your trucks look great. I am not quite sure if my mounting holes is in the correct position as it was already cut when I got the truck.
My spot light is missing all glass and bulb but the lamp housing is there. Can i get replacement parts?
It appears that in all cases the interior window trim has to cut to fit the light?
rc356s #1132072 10/30/2015 3:27 PM
OK, deer season has started and you're asking about spot lights? (Just kidding.)
rc356s #1132110 10/30/2015 9:41 PM
Gas Pumper
Gas Pumper
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
rc356s #1132327 11/01/2015 1:17 PM
Dad;
That is a real good looking install. I've often toyed with the idea of installing a spotlight on my 58 Burb. Does the light stick out far enough to the side that you can swing it around behind you for backing up? That would be a cool capability to have to augment backup lights.
Larry
rc356s #1132408 11/01/2015 8:52 PM
Not sure , I'll give it a try tonight
I'm using a b-31 back up lamp on the bumper. It works pretty well for the size
rc356s #1132677 11/03/2015 8:48 AM
Roger. Thanks.
Larry
rc356s #1132708 11/03/2015 3:37 PM
You can aim it to the rear
It worked ok on a pick up because you can look out the back window.
Not sure how well it would work on a burb
Maybe post this in the panel and burb section of the forum for better help.
