5 members (Donf, TUTS 59, Gdads51, massey1951, JW51), 90 guests, and 2 robots.
Topics128,038
Posts1,055,583
#1132523 11/02/2015 10:44 AM
I completely rewired my '41 half ton with a harness from Rhode Island Electric. Everything went well with the exception of the gas guage. I've gone through the usual tests. I've got power to the guage, ohm reading across the guage terminals. Sending unit tests OK.
What am I missing?
Ed Lepelis #1132536 11/02/2015 2:08 PM
Ex Hall Monitor
Ex Hall Monitor
What is it doing that it shouldn't or not doing that it should? Is it reading full all the time? Is it reading empty all the time? More info for us helps us to help you.
Tiny #1132537 11/02/2015 2:44 PM
Reads empty no matter what I do. No movement of any kind.
Ed Lepelis #1132589 11/02/2015 9:15 PM
V
VEW Offline
V Offline
6V, I presume. Sounds like it could be the connection between the sending unit and the gauge, since everything else is checking out. You could run a wire and see.
~ Victor
1957 3100 - moved on
