2 members (wilbur53, rfs56trk),
73
Mod | | | Forums66 Topics128,264 Posts1,058,357 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Hi All. I am new to the stovebolt page so bear with me. I bought a 51 3100 5 window in a basket case and I am not sure if I have all of the parts. My question is, is there a bracket to bolt the inner fender and the toe board together on the passenger side. I was talking to a restorer tonight and he thought there was one on both sides. I have the factory assembly manual, but it just shows the drivers side, with the parking brake assembly and bracket to bolt toe board and inner fender together. Any help would be appreciated. Then I will know if I still have to scrounge up some parts to put it all back together. Thanks Eric | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Just the driver's side has the bracket. The passenger side inner fender bolts right to the firewall, toeboard. | | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Thanks brjr51. Where abouts is Mahattan, Ill. I am original from Taylorville,Ill. It is about 30 miles south of Springfield. Thanks again for the info.
Eric | | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | No problem, it's between Kankakee and Joliet. | | |
