1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#1132225 10/31/2015 6:51 PM
Now I know (thanks to Tim my newly purchased engine is a 1955, does anyone know if it will bolt into my 1949 truck with a frozen 1954 engine in it? Will I need to weld in new motor mounts in a different location? Thanks
There were two different engines in 1955. Both mount the same. But you will have to modify the water pump if it is a '55 second series engine.
Just read the other thread. A first series engine should bolt in place with no problems.
' Offline
I had to replace the original 235 Loadmaster in my 49 model 4400 1 1/2T. I put in a 1956 car 235 and had to do the water pump mod. Also had to replace the pilot bushing for the transmission. The 56 car engine pilot bushing is different and won't fit the 49 trans input shaft. I re-used the 49 pilot by shaving a few thousandths off the outer diameter.
George
billm #1132447 11/02/2015 12:55 AM
Thanks Guys.....can I post photos of the work done on the truck here?
billm #1132448 11/02/2015 12:58 AM
There are instructions at the lower left of this page.
Briefly: if you have a photo hosting account somewhere, they will have a way of giving you a "public" link to a specific photo. Copy that link and paste the link on a line in a post here.
Authorized Pest
Authorized Pest
Billm,
Sure you can post LINKS to photos. We don't actually have the pictures here (as stated in the policy Tim referenced on the bottom left). But links - sure -- the more the better.
Peggy M
~ Peggy M
1949 Chevrolet 3804
A new forum has just opened called Project Journals. You might want to start a thread of your progress there.
Authorized Pest
Authorized Pest
Actually, the best way to get into the Projects section (kinda like interning) is to start your "build / project thread" in the Engine forum. After you get to a certain point, John will have a chance to check it out.
We do hope to have more than just truck resto in that section. Right now, we are working out any bugs in the set up. So, starting in Engines will at least give you a start with some feedback and make it easy to move it to Projects when ready.
Peg
~ Peggy M
1949 Chevrolet 3804
